RCU Forums - View Single Post - Falcon 40 (Exceed heli) Forum
Old 05-14-2007 | 03:19 PM
  #1118
ronf79
Default RE: Falcon 40 (Exceed heli) Forum
Rdrunner,
Switch the servo plugs and see if the glitch follows the connection or if the same servo is glitching. That way you will be able to tell if it is just a servo and not your 4 in 1. If the same sevo glitches even though you switched the plugs, you know it is a problem with that servo.
Hope that helps,
Ron
