RCU Forums - View Single Post - Predator outrigger [project]
Old 05-14-2007 | 03:50 PM
CadillacDTS2001's Avatar
CadillacDTS2001
Default RE: Predator outrigger [project]
ORIGINAL: mahogany dreams
the only advice i can give you is that you dont want to turn your cable the opposite way that it is twisted!!! currently the cable is the wrong lay for the props you have. also, if you run that cable, it will greatly reduce your number of prop choices!!
of you have ever seen a flex shaft you would know it does not have any particular direction.
take it apart and you will see each layer is wound a different way. just because you see it going right does not mean it can not turn left. . or vica versa. I run it that way on my Lehner powered N2 and P offshore boat. i do not have a problem with them at all.
