RCU Forums - View Single Post - Axe cp tail rotor
Old 05-14-2007 | 09:50 PM
mrasmm
Default RE: Axe cp tail rotor
oh, I guess it could also too be the prop slipping. If you have gear drive make sure that your pinion is tight, that the gear is meshing properly and is attached to the prop so nothing is slipping. If you have a DD 3020 or 4530 system, make sure the prop is not slipping on the shaft.
