RCU Forums - View Single Post - Wheeeeeeee.......... Blade CP!
Old 05-15-2007 | 05:51 PM
  #2912
crashcrash
Default RE: Wheeeeeeee.......... Blade CP!
Since I've got the DX6...shouldn't be a problem setting them up. I won't put it together till ALL the stuff gets here either. I just won't fly without Bell-Hiller...I'm spoiled rotten. Won't fly without the Auto Rotation either...Twice spoiled, I really like those features.
ORIGINAL: choppersrule
Crashcrash and Mrasmm,
The HS-55's servos are probably the best servo for the Blade CP/Pro for the price. Mrassm, I forget do you have a programmable radio, because the HS-55's turn the opposite direction than the Stock S75's. But can be modified electrically to work with the Stock Transmitter for the Blade series. With a programmable Transmitter it can be done in the menus.
I've mentioned this before,,, take a new stock 75 and a new 55. With finger tip pressure on the servo arm, the 75 will move up or down. The 55 has NO slop. I have 55's on my Pro and ordered 55's for the test bird(CP).
I'll just take a minute here to be silly again, "NA-NA-NA-NAAAA-NA", I got mine yesterday. Still in the box.
Crazy Dave / Choppersrule
ORIGINAL: mrasmm
ORIGINAL: crashcrash
Sounds pretty close to what I had except mine was severe and the 3-1 would disarm, and the glitch was severe too. I got 3 HS-55's on order (servos). It didn't happen all at once, it was progressive in nature where it would finally cause crashes.
Would the servo's do weird things also, or just the motor cut out? I might need to just get me some 55's anywho, they sound like alot better servo.
