RCU Forums - View Single Post - G51 Compression problem
Old 05-15-2007 | 08:54 PM
snowbelt
Default RE: G51 Compression problem
I am experiencing the exact same problem you are describing with a set of G51's that I am putting on a Seagull Dual Ace. One is running half decent, and the other will barely run due to low compression.
Debris Field, did you run it anymore before putting it away for parts?
