RCU Forums - View Single Post - Hangar 9 P-51 problems?
Old 02-27-2003 | 03:04 AM
chad-RCU
Default Hangar 9 P-51 problems?
Hey guys what engines are yall running. I have the saito 100 and as for the snapping on take-off. Well mine didn't do it. To make you feel better i held full up untill the plane left the ground. the 14*8 master airscrew almost pulled it straight up. No sign of stalling. The plane is sweet it reacts well but is very smooth. It doesn't whip around like say an unltra stick. As far as landings go do not try to come in high. The plane is very slick and will not slow down very fast. On your initial landings make a long approach and come in low. WHEN YOU LAND YOU SHOULD JUST ABOUT HAVE THE ELEVATOR FULL UP. THIS WILL ELIMINATE THE NOSE OVER PROBLEM.
Gene375 don't worry about the maiden just be CALM. What other planes do you have. I am trying to figure out your flying skills. Hence you should be able to handle it.
