RE: Engine problems
The LHS owner said low compression keeps fuel from reaching the plug causing it to burn out. It does seem to do it more when it's being run slow? Seems odd that would happen but might be true.
I know the compression is low so I'm going to install a new piston and sleeve and then shim it as well.
