RE: 50cc Sukhette Build Thread, now in progress!!
Sigh.
That's the choke. I have been using this type of connector for 10 years on light-duty linkages like this and never had a problem. This allows easy setup and adjustment of the pushrods.
What happens if it comes loose? The screw doesn't come loose. It's mounted in a brass fitting that really hold tight.
Re: the zip tie, you put another length of silicone tube over the part of the zip tie that's against the muffler.
I'll do some better photos tomorrow. This is a really slick way to mount the canister.
