RCU Forums - View Single Post - G51 Compression problem
Old 05-16-2007 | 07:23 AM
Debris Field
Default RE: G51 Compression problem
No I've laid it up carefully for future scavenging!
I now have however got a replacement piston and liner on the way which i hope will cure the issue. The replacement motor is just fine and after matching the other engine for run time first has performed sweetly since.
Cheers
Mick
