RCU Forums - View Single Post - Homebrew Mini V Hull with Outrunner
Old 05-16-2007 | 09:13 AM
crashbuilder
Default Homebrew Mini V Hull with Outrunner
Hi there,
I’m new to boats (mostly fly slope gliders) but I’ve mean playing with this little concept …. Just something to mess around with.
Specs:
Length 14”
Beam 4”
Deadrise at transom: 11 degrees
Motor: TowPro Brushless Outrunner 2408-21 Delta
https://www.unitedhobbies.com/UNITED...idProduct=4321
ESC: A 12A
Battery: 8-Cell 1100mAh NiMH
Here are a couple questions:
1. Will a boat like this need lifting strakes or chines? See Pic. What’s the best way to make/add them?
2.What’s the best way to shim a threaded 3.2mm motor shaft to fit a 1/8” solid coupler
http://www2.towerhobbies.com/cgi-bi...p?&I=LXJ759&P=0
OR
Should I use a Dumas dog bone universal … I’ll still need to shim the shaft
http://www2.towerhobbies.com/cgi-bi...p?&I=LXE444&P=0
3. I plan to run a solid shaft surface drive; can I use any of these (I’ve got these)
http://www2.towerhobbies.com/cgi-bin/WTI0001P?&I=LXE472
http://www2.towerhobbies.com/cgi-bin/WTI0001P?&I=LXE471
http://www2.towerhobbies.com/cgi-bin/WTI0001P?&I=LXE470
http://www2.towerhobbies.com/cgi-bin/WTI0001P?&I=LXMNM5
4. How far aft of the transom should I place the prop; I’m thinking @ 2.5”
5. How much freeboard do you need to be safe? My float test, with gear, showed that I only had a 1/4” clearance at the stern. Maybe I need some smaller batteries.
Any comments or suggestions welcome
