RCU Forums - View Single Post - Identify this seaplane
Old 05-16-2007 | 11:02 AM
Turbobeaver
Default RE: Identify this seaplane
Jonawald,the model that you are trying to identify is indeed a Pilot Lake LA-4.This particular kit was manufactured by Pilot kits (OK Model Co.)back in the mid 70's to mid 80's era.As far as I can remember,Pilot was the only kit manufacturer ever to have produced a kit of the Lake Buccaneer .This particular model could be configured to be either a pusher version for scale or tractor for sport flying.Most went with the tractor pod version because of better engine cooling and you didn't have to go searching for a proper size pusher prop(which were not the easiest to come across back then).The tractor set up also placed the engine further forward on the fuselage which meant less ballast was required up front to achieve the proper C of G.If your interested,check out this site below for more information and history of the LA-4 and the other versions:
http://www.teamlake.com/
The Lake line started with the Colonial Skimmer. Colonial Aircraft Company first flew the Skimmer in 1948. Lake Aircraft introduced the LA4 (180 HP) in 1960 and the LA4/200 (The Lake Buccaneer) in 1970. Lake Aircraft first introduced the LA 250 (The Lake Renegade) in 1984 and the Turbo Renegade (270 hp) in 1987. In 1994, Lake introduced a new product with a salt water “beef up” for added corrosion protection, the Seafury. Today, the Seafury and the Seawolf, a military version, are still being produced.
