RCU Forums - View Single Post - throttle spring needed?
Old 05-16-2007 | 12:31 PM
busta9
Default throttle spring needed?
Is the spring that closes the throttle needed? If I leave it on, the slider in the carb will not open all the way......the servo will hold the slider closed so is the spring really needed?
I have a savage x with a stock throttle/break servo....which I plan to upgrade for sure considering the servo is not powerful enough move the throttle to a fully open postion unless I pull back fast on the trigger.....the batteries are good too.
