RCU Forums - View Single Post - Building From Plans :'(
Old 05-16-2007 | 12:48 PM
dmcmike
My Feedback: (14)
Default RE: Building From Plans :'(
Once you decide on your subject, get the plans in hand, and take them to a blueprint shop. Have them make several copies, as many as you can comfortably afford. Then you'll have patterns to make your parts from. Get the lumber, then using an X-acto, scroll saw, band saw, sandpaper, etc. cut out your parts, labeling them as you go. Once you have the complete 'kit' of parts done, you'll find its really no different than building a regular production kit. Sure, there may be some 'details' that have to be worked out, but just use good common sense and you'll be more than rewarded once you finish and get that bird in the air!
Good Luck!
