RE: Can't Get new Enging to Turn Over
Well I always set to factory settings, then lean it out a little so it will idle OK, pull off OK and runs OK if a little slow due to richness, and break in like this. Breaking in at factory settings doesn't get the temps high enough for heat cycling.
It does need to be a little on the rich side but not 'slobbering' rich
