ORIGINAL: alan0899
If you keep adding down thrust, you will also need to add, up elevator, when straight & level, & this will make it even worse, when inverted, as the up elevator will be pushing the nose DOWN, when inverted.
I just re-read this part so maybe I've added too much down thrust.
