RCU Forums - View Single Post - Good third plane?
Old 05-16-2007 | 04:19 PM
pt40crasher's Avatar
pt40crasher
Default RE: Good third plane?
The stryker can be a docile flyer and I know people who learned on it. It is very easy to land. However, as you pointed out, if you get into the throttle or horse it around too much and it will get away from you. It will eventually get away from you anyway if you fly it fast and low like we all like to. The up side is it is cheap and easy to repair. There are electric high wing trainers available if you don't want to mess with glow stuff. It all depends on where you want to go with it. The DX6 is only suited to parkflyers and small electrics. This one: http://www.horizonhobby.com/Products...ProdID=EFL2250 is good as well and suited to your radio. 5 min epoxy does not go as far on the ultra stick as it does on a foamie for repairs, though.
