RCU Forums - View Single Post - Wheeeeeeee.......... Blade CP!
Old 05-16-2007 | 05:14 PM
  #2925
Atzanik's Avatar
Atzanik
Default RE: Wheeeeeeee.......... Blade CP!
ORIGINAL: sportsman67
Thanks for the info, sounds like your setup might be running pretty close to what mine is. Good to know on those sym blades. I'm not used to them because I haven't been running them in quite a while (ever since I found these $3.75 a pair flats). Sounds like a good idea on the lube, what lube are you using?
Where are you buying flats for $3.75 a pair??? I'd be interested in stocking up at that price.
