RCU Forums - View Single Post - Wheeeeeeee.......... Blade CP!
Old 05-16-2007 | 05:40 PM
  #2926
lookyj
Default RE: Wheeeeeeee.......... Blade CP!
mrasmm,
thanks for the info. I kinda figured I burned up the pack by charging at the wrong charging current. The stock E-Flite Balancing charger that comes with the CX2 (EFLC3110) is rated at 0.65A output, the stock E-Flite Balancing charger that comes with the CP Pro (EFLC3105) is rated at 0.8A output...
stock E-Flight battery specs
7.4V 800mAh 2-Cell LiPo, JST/Balance: BCX/2
Product Specifications
Type: Lipo
Capacity: 800mAh
Voltage: 7.4V (nominal)
Connector Type: JST (BEC) for discharge; E-flite Balance Connector for balance charging (Use EFLC3100 Balance Charger only)
Wire Gauge: 20GA
Number of Cells: 2 series
Weight: 1.5 oz
Dimensions (WxLxH): .95 x 2.75 x .50
Application: E-flite Blade CX (EFLH1200)
Maximum Continuous Discharge : 10C
Maximum Burst Discharge : 12.5
Maximum Continuous Current : 8A
Charge Protection Circuitry: Yes, via E-flite Balance Connector only (Use EFLC3100 Balance Charger)
11.1V 800mAh 3S Lipo, JST/Bal: BCP, BCPP
Type: Lithium Polymer (Li-Po)
Capacity: 800mAh
Voltage: 11.1V (nominal)
Connector Type: JST (BEC) for discharge; E-flite Balance Connector for balance charging (Use EFLC3105 Balance Charger only)
Wire Gauge: 20GA
Number of Cells: 3 series
Weight: 2.3 oz
Dimensions (WxLxH): .95 x 2.75 x .70
Application: E-flite Blade CP Pro (EFLH1300)
Maximum Burst Discharge : 12.5C
Charge Protection Circuitry: Yes, via E-flite Balance Connector only (Use EFLC3105 Balance Charger)
Anyone know the max charge current I can use with the stock E-Flite Lipo's without damaging?
