RCU Forums - View Single Post - Fliton Extra 260 Mini Set-up time!!!
Old 05-16-2007 | 06:08 PM
Shawnlh's Avatar
Shawnlh
My Feedback: (-1)
Default Fliton Extra 260 Mini Set-up time!!!
Ok, I have my name on a new Fliton Extra 260 Mini and I need to ask you guys if the system I have in mind will work. From the other build thread and Flitons info, the plane should come in between 24-26oz depending on the power system. This will be my first electric airplane and used for mostly 3D. Here's what I was thinking:
Motor: AXI 2217/16
ESC: CC35 Pheonix, or CC36 Thunderbird
Batt: TP 2100 Prolite
prop: APC 11x5.5
Servos: Futaba S3154's all around
My concern from reading the forums here is, will the digi servos overheat the bec? And what ESC is a better choice? I would like to try and get it right the first time as I have to mail order everything.
I'd like to tell you guys where I got the plane from, but I'll have to charge you for it
