RE: On board camera filter
A 1uf tam cap put across the pos and neg main motor may help but I would use a seperat batt for the cam. Most mini cams will run off a 9volt batt. Check the specs of the cam and see if it will run off a 9v batt first. If so then try it out and see if that helps.
