RCU Forums - View Single Post - DF Training Wheels
Old 05-16-2007 | 11:25 PM
Old Man Mike
Default RE: DF Training Wheels
I've considered putting on the LEDs but keep thinking that they would not show up in bright daylight. I suppose I should give it a try. In the meantime, I'm using some bright colored reflective tape on the frame and on the training protector tubes. It is really easy to see even when lighting is poor. By the way, one other advantage with the protector tubes is that you can move the DF around the carpet like a car since it does not allow enough tilt to restrict movement. That helped a lot during early training since you can get a feel for the movement without actually hovering.
Mike
