Well here is the list!
Well guys here is my project parts list!
Madd Force Adaptor Kit
http://www.maximizerproducts.com/maxstore/stores/1/Madd_Force_Adaptor_Kit_P83C8.cfm?UserID=224729&jse ssionid=2430905e0200$F5H0$FB
My clutch combo
Hot Bodies Flywheel for 2pc Shoe Lightning
http://www2.towerhobbies.com/cgi-bin...p?&I=LXHZK7&P=
Hot Bodies Clutch Spring 3-Shoe Lightning (2)
http://www2.towerhobbies.com/cgi-bin...?&I=LXEPA3&P=7
Golden Horizons Alum Clutch Shoe Prpl Savage 21/25/28SS
http://www2.towerhobbies.com/cgi-bin...?&I=LXFZZ8&P=7
My diff set up
HPI Bearing 10x16x5mm Savage 21 (2)
http://www2.towerhobbies.com/cgi-bin...=++&search3=Go
HPI Heavy Duty Differential Shaft 14x34mm Savage (2)
http://www2.towerhobbies.com/cgi-bin...?&I=LXGJU3&P=Z
HPI Alloy Diff Case Savage X SS
http://www2.towerhobbies.com/cgi-bin...?&I=LXPLW0&P=Z
HPI 4 Bevel Gear Differential Shaft 4x27mm Hellfire (4)
http://www2.towerhobbies.com/cgi-bin...?&I=LXLZX9&P=Z
Hot Bodies Differential Gear Set Hard Steel Lightning
http://www2.towerhobbies.com/cgi-bin...?&I=LXLGV5&P=X
Hot Bodies Bevel Gear Spiral 10T Lightning
http://www2.towerhobbies.com/cgi-bin...?&I=LXJBM3&P=X
Hot Bodies Bevel Gear Spiral 43T Lightning Stadium
http://www2.towerhobbies.com/cgi-bin...?&I=LXJBM4&P=X
My drive shafts
Hot Bodies Heavy Duty Dogbone
http://www2.towerhobbies.com/cgi-bin...?&I=LXJKM7&P=7
Replacement parts
Suspion arms x2
3speed gears
brakes
kyosho long drive cup
center bulk
body posts
kyosho engine mount
bell guide
3pice clutch nut
Wheel and tire combo
Big joe tires and wheels,
imex web rims,
maxx onroad tires
will have pics of the web and tire in a bit!
Lst2 shocks
carb bolt for the mach
new ball bearing in the diffs!
Well thats it for now! I will keep u updated!
