RE: Small Muffler Big Engine?
Magnum 108, older OS 108 both fit right up as do the various aftermarket Pitts style mufflers. If the port and mounting bolts match go for it. The only problem would be restriction and that would be apparent by lack of rpm. The Magnum/ASP does not turn high anyway, maybe 9k or so. If you don't over prop or run lean you won't hurt it.
