RCU Forums - View Single Post - Dubro 2-56 Pull-Pull Help
Old 02-27-2003 | 01:50 AM
MHawker's Avatar
MHawker
My Feedback: (16)
Default Dubro 2-56 Pull-Pull Help
I have not used the Du-bro version, but the Sullivan came with a threaded rod. Does the Du-bro have one of these? It should be a small threaded rod with a hole in one end for the wire.
If not, go to the hobby store and get a couple of 2-56 eye screws. Use these on one end and that will allow you to adjust the tension since you can screw them into the clevises. Remember to put a locking nut on them also.
Good luck!
Mike
