Dubro 2-56 Pull-Pull Help
Get them as close as you can (leaving some of the threads showing on the cable studs for adjustments) and then remove one clevis (or ball link) from the control horn. Make the final adjustment of the cable so once it's crimped you'll have to pull it snug to hook the clevis back up. If you have to tighten them after that just remove the clevis (or ball link) and screw the stud in a little.
