RE: Trim wheels and brakes setup
I never glued the tires or greased the valve. I guess sooner or later it may require grease. One thing: be certain that your actuation servo does not pull the plunger too far out of the valve (old style, I think they improved this on later versions). If it does, it sometimes will not line up correctly to go back in and will jam thereby stalling the servo and not allowing any braking.
