RE: Custom Mini Lighting system?
You can get 9v leds from E-bay as well as other voltages but most leds are rated for 3 or 5 volts and 20 miliamps max. [link=http://led.linear1.org/led.wiz]Here[/link] is a calculator that you can use to calculate resistor value, you want to connect the leds in parallel.
