RCU Forums - View Single Post - Stingray Construction
Old 03-21-2003 | 06:17 PM
  #121
Shaun Evans's Avatar
Shaun Evans
Default Stingray Construction
Guys,
Don't NOT install your speedbrake on top. Be careful about how you hinge it, make sure your angles and everything are right so that it doesn't want to twist one way rather than another. If every Stingray built has the same problem with the aircraft dropping off to the right when flown, then okay.
We're installing speedboards on all three gear, with a big one on the front. We'll get her slowed down.......
JPOFL,
Thank you very much for the insight and invaluable info!
