I reset the whole radio. If I do NOT pull max current...no problem...I flew tonight. Lacks headspeed, won't stay airborne very high or long. Adjusted the pitch to compensate. I'm betting now on a bad 3-1 because sometimes the tail goes batty too. I'm not getting enough juice to the main motor to maintain decient head speed and if I overdraw current (steady red) with pressure on the servos...it shuts down (3-1) and I have to stop and re-arm it. """3-1 is bad???""".
ORIGINAL: choppersrule
Crashcrash,
Holy Crap... What's next for you..
Does the DX6 work okay with the planks? You may want to reset the DX6 transmiiter and reinstall setting for the heli. Or maybe take one of the receivers from the planks and install in the heli. I know the feeling exactly, I've thrown out two heli,, The Falcon 3d and the Raptor G2 (Walkera). Between the cost of those two helis and parts, I dumped about a grand on them. . It can be extremely frustrating at times and expensive.. Maybe time to take a breather.
Sincerely,
Dave / Choppersrule
ORIGINAL: crashcrash
New sevos didn't solve the problem. Pulls the servos down during arming and comes back. Then running it wide open the servos pull hard down and I get either a dim green light or flashing between red and green dim light. Down to radio or 3-1. Personally I think it's the radio with it's inherient collective problem I've read about. Either way...$$$...lots of it. I'll try the 3-1 first and if that don't fix it...who knows, time to locate my 20# hammer and fix it for good. I'm about done with this stuff.
