RE: Carb too small? How do I know?
Sort of. They didn'g glue/weld it into the hole like yours, they welded it to a plate and attached it with the two screws close to yours. It covers that whole side with the pipe sticking out like yours, only a bit further I think. I was going to remove it because I thought if the seal between the plate and the carb wasn't air tight then covering the pipe would have no affect as air could still get in. I don't see why it's needed, cowl pressure would be better anyways. Anyone know what these pipes do or are they just for show?
