RCU Forums - View Single Post - Don't you just hate it.....
Old 05-17-2007 | 11:58 PM
Cyberwolf's Avatar
Cyberwolf
Default RE: Don't you just hate it.....
I would make sure you know the product and how well it works, some of those good buys are not so good if you can't use it.
I bought some off the net and threw away 3 bottles of the crap. Check out tower if your looking for a larger quanity, so far I have had good luck with it with the exception the med is a little on the thin side.
As a rule I don't let mine set around long enough for it to go bad, but the fridge is the best idea from what I have seen and read, Make sure you seal it up good also.
