RE: Fliton Extra 260 Mini Set-up time!!!
The Power 10 would be way overkill wouldn't it? And way too heavy.
I would imagine you would be more in the Park 450-480 class with a weight of 24-26 oz.
Another motor choice would be the HiMaxx HC3510-1100 a little more power than the Axi 2217/16 - you could get away with the Phoenix 25, but the Phoenix 30 would be playing it safe.
Are you hooked on using the digital servos? Or maybe look at the HiTec hs65hb with the karbonite gears.
