RCU Forums - View Single Post - Increasing Throws
Old 05-18-2007 | 01:38 PM
CGRetired's Avatar
CGRetired
Default RE: Increasing Throws
Most of all, remember to re-center the control surfaces after moving the position on either the servo end or the aileron end. It may change slightly. How much it changes is depending on the amount you change the position of the rods. It may not require an adjustment but always worth the check to make sure they are properly centered.
Remember, no matter what you do, you will also need to re-trim the aircraft in flight so your first flight after the adjustment should be done with some caution and very slowly. In other words, don't go off full throttle and start to make violent maneuvers until you are able to fly straight and level with 'hands-off'.
DS.
