RE: balancing propeller
It's not a bad idea to do this with EVERY prop.
Some props come somewhat balanced from the factory, others need some work.
The more balanced the prop ( and don't forget to balance the SPINNER TOO! ) the less vibration the plan may be subjected to in flight and on the ground.
The engine also gains a bit of efficiency too.
