RE: Diff oil
For the inside of the diffs you can use oil or grease. With the grease just enough to coat the gears. With oil use a 100% silicone oil made for RC's fill them 3/4 full or just above the last small gear inside the housing. There should be a paper gasket to seal it from leaking, but you might need a new one if it does leak out.
