RCU Forums - View Single Post - Eco 8 setup
Thread: Eco 8 setup
Old 05-19-2007 | 10:25 AM
stevehickey6
Default RE: Eco 8 setup
hi all i have had my eco 8 for some time now and still not had courage to fly it but i have started to try set her up again after a long break
i have the ikarus sport motor that was supplied with it
i am using a jr 2610 radio
i have fitted a few upgrades as sugested in a lot of forums back when i was assembling it
could someone please help me with a few settings if possible
i can set expo on my tx so i can soften the reactions on tx as i am a bit heavy handed with controls but i am not sure which ones to set
do i leave throttle alone and just set the pitch aerlon and roll think thats what they are called
also i have seen on some videos they set a negative % figure but this was on a futba radio i also saw somewhere but for life of me cant find it now that if you have a jr radio you set a plus figure to soften the controls is this correct ??
i am using a standard 9.6v battery at min
but would like to upgrade to a lippo and a brushless motor and controller any advice please not the very latest as i am on a budget so the cheaper the better as i will not be doing any real fast 3d for a long time
any advice on pitch , throttle curves would be a great help even a base figure for hover and slight 3d settings
as for gyro mine can do normal and heading lock via tx any advice on which would be better for a newb
any help at all much appreciated
thanks
