y-harness on elevator
Hi,
I was considering purchasing a Futaba 7CAP transmitter, but realized it did not support two elevator servos (as used on some 3d planes). I understand that two channels can be mixed together and therefore essentially accomplish the same effect, but this allows trimming of only one side of the elevator.
Is it possible to use a Servo Reversing Y-harness off of channel 2 in order to make two Futaba 3151 servos act in conjunction with each other? It is my understanding that doing so will essentially turn the elevator back into a single servo elevator with twice the torque. Is this correct?
Would you recommend any other Futaba transmitters? (I'd prefer stay with Futaba)
Michael
