RE: y-harness on elevator
The chanel mixing gives you the best control. You can trim out each servo, including sub trim and throw. However the front pannel trim works like a single servo. Give it a go on the bench and I think you will be pleased. Oh yes, just don't set the mixing up as switch activated. The last thing you want is to bump a switch and end up with only one surface for control.
Don
