RE: Adjusting the prop shaft angle via radio/servo
It requires the servo to be modified so it can spin continuously either direction and a driveshaft attached that goes to a fine thread jackscrew that is tapped into a hinged motor plate.
A standard servo with an arm is not shock proof enough for it to be used as the brace.
I've never experimented myself but have seen how they are made.
