RE: y-harness on elevator
One of the main draw backs to the 7c is that it does not allow you to mix channels so the other options mentioned are your only choices. If you have not bought your radio, you might want to select a model that does allow channel mixing, such as the Futaba 9c. I know there are others that allow mixing, but I am not familar with all the models numbers as I am a Futaba kinda guy. Good Luck, Dave
