Stabilizer Flybar - Shaky CX2 - Is that the problem?
After a slight accident my Blade CX2 became a bit shaky, and a little more difficult to control. The upper and lower blades are not damaged at all, and seem to be in perfect condition. The inner shaft seems to be unharmed too, although I would consider it very difficult to damage it before breaking off the blades first.
I suspect that the problem is caused by the stabilizer flybar, but that doesn’t seem to bend that easily, and I can’t really tell if it’s actually bend. But from what I can understand, just a slight bend on the flybar, could be causing this problem. Correct me if I’m wrong.
Everything else seems to be just fine, and the hit wasn’t that hard. What could be causing this shaky reaction on my Blade CX2?
