RCU Forums - View Single Post - Large C-5 project started!!
Old 05-20-2007 | 04:50 PM
NickC5FE's Avatar
NickC5FE
My Feedback: (31)
Default Large C-5 project started!!
Ok, i started my next BIG project. I found the original blueprints used to build c-5 models large scale to c-5 customers. I will be designing this for 2 wren 44 golds. Construction will be of blue foam formers sandwiched with ply in high stress areas. The wingspan will be 100 inches and the same long. The vert stab will detach from the empennage, and the horizontal will detach from that. The empennage will detach from the fuse behind the wingroot, right about at the troop doors 7l and right. The nose will be operable open and the wings will have L.E Slats and all the flaps with scale tracks. I will post as i can, as time is fairly limited now. Nick
Oh yeah, i will be designing the new C-5M Engine cowls to fit the 44's. The entire plane will be F/G covered
