Nitronuts,
The HS-55 will work on the Pro if your using the DX7. The HS55 servos, turn in the opposite direction than the stock S75's, that the Pro comes with. You can change the direction in one of the menus on the DX7. The HS55 are much better than the S75's, they have zero slop in them, compared to a S75.. You could also use the HS55's with the stock Blade Transmitter, but a wiring modification needs to be done to reverse the direction of the servo motor. When installing the HS55, make sure that the lower tab on the servo is seated properly. I had to trim about 1/8 inch of the bottom of the tab.. Other than that, you'll love 'em.
Dave / Choppersrule
ORIGINAL: Nitronuts
Thats a bummer, sounds like my luck
I cant wait to get the Blade CP Pro tomorrow. I will be transfering my DX7 Radio and AR6100 reciever to it.
My Axe will be going on the big E.
Will the Hitec HS-55 servos work in it? I have 3 of them looking for a home.
