how many Lbs can a TT46 pull?
How about putting a metal motor mount on it would add strength
would be cheaper than a new spinner or motor
you can also change the firewall make one out of 3/4" plywood(~ 2cm.)that would also add strength plus weight.
make shore your battery pack is in front of your rec. in front of cg.
