how many Lbs can a TT46 pull?
Make sure you balance it all put together and with fuel tank empty. measure from front of wing to where it says, then out your fingers there and see if it holds a balance.
See what your directions say on how many inches back you need to balance from. I would do that before adding lead to it. Usually they are very close to balance from the start.
