RE: RS4 18SS+ CLUTCH QUESTIONS?
You have an open diff which means one wheel will spin the other direction from the other.
If you can roll your car forwards and backwards smoothly without binding then your drivetrain should be fine. Double check the 2speed and clutch bell again, they both go in a special direction
