RCU Forums - View Single Post - Determining and measuring the proper thrust line when mounting
Old 05-20-2007 | 11:38 PM
rino
My Feedback: (121)
Default RE: Determining and measuring the proper thrust line when mounting
I found the trig method a bit hard because it is hard to measure that accurately with a ruler or a tape. I leveled the aircraft with a level on the canopy base which seems to run exactly straight with the fues. I could then easily see with a small level on the backside of the motor (horizontally mounted) that I had a slight amount of down thrust. The funny is that it appears that the firewall also has some down thrust built into it. This may be intended or may be a flaw. Using the line I established the tail also had a slight amount of negative incidence which I found to be surprising.
So, I need to take my measurements again leveling off of the cord line. However, I don't have any tool to determine what the cord line is.
