RCU Forums - View Single Post - Started it up,need some quick help!
Old 05-21-2007 | 01:27 AM
naynay12
Default RE: Started it up,need some quick help!
Ok well had to cut it short since it was raining.I turned the idle screw clockwise a turn and it was not bad.All the needles were lean,sicne he came from i n the mountains of america.
He said when he broke it in first he idled for to tanks,the after every tank he leaned the needles 1/8 of a turn.He ran 6 tanks-thats all...a bit fishy..He did not run it over 170f,and it was popping weelies.I ran around 200f,once up to 233f,and when i pressed half throttle the front end wpould on go slightly up...But its suppose tlo weelie?It was so rich at one stage that it reached 108 f,since i took the foil of the headMaybe i was babying it a bit since it already had 6 tanks through it...
Next weekend im going to the bmx track,running a few mopre tanks in the morining,then leaning it and jumping..Will this be ok?Also what alloy shoes should i go with,and howlong will the plastic ones last?
P.S i will soon post a video and you can tell me if i was running too rich.Thanks.
