RCU Forums - View Single Post - SMOKE OIL INJECTOR LOCATION
Old 05-21-2007 | 02:33 AM
Hooked-On-RC's Avatar
Hooked-On-RC
My Feedback: (16)
Default SMOKE OIL INJECTOR LOCATION
I am running a DA100 with KS Canisters and want to add smoke oil injectors. I am running a Sullivan Skywriter smoke pump that is using a programmed mix with my throttle channel. Where should the injectors be located?
1) Header pipes close to the exhuast port, say 1" from the engine?
2) Header pipes about 4-5 inches from the exhaust port?
3) In the Canister muffler itself?
4) How much of the injector should be inside the header pipe?
thanks in advance.
