Do all of the above...and
...instead of using a Dremel tool use a full size drill. Find a bolt that is the same diameter as your crankshaft end. Put it through the spinner backplate and use a double nut set-up to lock it in place. Chuck it up in the drill and polish away...you'll get a nice, even shine ALL around.
